Thread: Same Project On Two Machines
    11.04.2008
    40
    Daumen hoch Same Project On Two Machines
    I want to deploy the same project on two PC's.
    There is and keyswitch at one PC which will determine which PC can use a certain page (The page is for starting and stopping the system).
    The projects communicate to the same PLC and are networked together on Profibus.
    The end user does not want to use logn in with username and password.
    Is there any way of changing the autherisation level of machine without logging in??
    879
    Default Re: Same Project On Two Machines
    You can use the interlocking for this:
    - determine the location of the PC via the computername (String-Rema together with the Systemvariable "Computer name"
    - write the result to 2 Boolvariables
    - together via the PLC-Variable (status from the switch) create the interlocking rule (condition)
    - link the interlocking to the element
    also you can play with the visiblilty of the element
    - instead of the interlocking use a mathematic variable (bool - same formular as above) which controls the visibilty of the element
