Thread: REAL / INT value user input
    Default REAL / INT value user input
    Hello!
    I would need to create an input window where the user could enter an integer/real value which upon accept would write the REAL/INT value to the specified variable.
    I have been searching the forums for a while now but haven't managed to find much info about this.
    Could anyone tell me if this is possible on Zenon 7.11 and guide me atleast in the correct direction? Also I would like to know if the input window would read the input from virtual keyboard that is already available in the controller itself or must some kind of internal keyboard be generated (KUKA robot controller)?
    I have only recently started working with zenon so any help would be greatly appreciated.
  2. #
    02.07.2014
    27
    Default Re: REAL / INT value user input
    All Dynamic elements could be helpful in your case. You can use Numerical value for INT for example and for REAL you could use Dynamic Text element.
  3. #2
    18.02.2014
    22
    I guess you mean a kind of second stage confirmation, correct?
    Please check this link in the forum:
    https://forum.copadata.com/showthrea...onfirm-via-VBA
  4. #3
    02.07.2014
    27
  5. #4
    Daumen hoch Re: REAL / INT value user input
    Ah.. I thought that dynamic elements are only used for displaying readable values.
    Thanks alot - this was exactly the thing I was looking for!
  6. #5
    02.07.2014
    27
    You are welcome! I'm glad I could help!
    Best Regards,
    Stani
  1. Multible reaction matrix to same INT
    By martijnvanspijk in forum zenon Supervisor
    Last Post: 22nd May 2013, 15:17
  2. String Input
    By acko01 in forum zenon Supervisor
    Last Post: 10th March 2011, 00:02
  3. Input Values in Elements Windows Style
    Last Post: 27th October 2009, 17:31
  4. Modbus read input status
    By maurodx in forum Drivers
    Last Post: 2nd September 2009, 00:21
  5. digital input from field devices
    Last Post: 21st April 2009, 07:59
