Thread: Report Generation - Print .ARX pdf
    31.05.2013
    3
    Rotes Gesicht Report Generation - Print .ARX pdf
    I want to print .ARX file as pdf, however the outcome is not expected.
    .ARX designed is up to column j, however pdf printed is up to column f.
Name:	Report Template.PNG
    Anyone has idea how to adjust print area?
    Your guidance is much appreciated
    15.09.2016
    61
    Default Re: Report Generation - Print .ARX pdf
    at first try to change the pdf-printer to landscape. You can do this with the "select printer" function.
    And if this doesn´t help, try to adjust the width of your collums.
    I hope i could help you.
    31.05.2013
    3
    Quote Originally Posted by Florian L. View Post
    Hi Florian,
    Thanks for the reply. Yes, this doesn't help as I need wider width for columns.
    Understand the red line showing on report is the print border, do you have idea how to adjust this border?
    To set the print area.
    15.09.2016
    61
    The next I would Try is to change the Format to A3 in your printer.
    I think the Printborder is set by the size of the Page.
    but can you show me your report if you print it in landscape?
    31.05.2013
    3
    Hi Florian,
    Thanks for help, appreciated you are the only one who's reply.
    I've found the way to set the print area.
    You may refer attached photo for your reference.
  1. Report Viewer Pdf Export
    By Florian L. in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 7th November 2016, 14:54
  2. Default file name for report generation
    By synergyautomation in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 28th October 2014, 08:28
  3. Report Generation
    By sidramsatyal in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 30th June 2014, 08:53
  4. Time axis in the pdf print
    By hamid in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th September 2011, 09:42
  5. Print data from extended trend and reportgenerator in one report
    By gralex in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th August 2011, 08:22
