Thread: Zenon energy edition 7.50 SP0 zendbsrv is not running
    22.12.2016
    8
    Default Zenon energy edition 7.50 SP0 zendbsrv is not running
    I have installed Zenon energy edition 7.50 SP0 on windows 7 computer and managed to open the editor. However, it cannot create any new projects nor can it open the already-made workspace with the error: "'zenDBSrv' on localhost is not running". I don't see this service in the services part of windows so I don't know if the installation has been successful or not. Any ideas on how I should handle this problem? Any help is appreciated. Thanks.
    /Mehrdad
  2. #
    15.11.2016
    106
    Default Re: Zenon energy edition 7.50 SP0 zendbsrv is not running
    Hello Mehrdad
    Then zenDBSrv is the process that connects to the SQL database where the projects are stored.
    It automatically starts together with the editor.
    But it can happen that the zenDBSrv can not connect to the SQL Database in which case the process closes itself.
    1. SQL-Instance is not running
    2. password for login was incorrect
    3 zenon-sql-user does not exist in the SQL database
    1. Is unlikely.
    -> check SQL server configuration manager to make sure.
    2. Can happen if there was a previous version of zenon istalled and the existing user-pw was not correctly aplied.
    3. Can happen if there is a security policy that prevents a user creation if the user-pw is to short.
    -> 2 and 3 would create an entry in the windows event log stating the reason for the failed login.
    I hope this helps a little.
    BR,
    Georg
  3. #2
    15.01.2016
    92
    Hello
    You could try to register all services new by clicking here:
    If i still not working make shure that the zenDBsrv is running, and try again
  4. #3
    15.11.2016
    106
    Hello Mehrdad
    1. Is unlikely.
    BR,
    Georg
  1. Zenon client in OWS (Operator Work Station) not running from Server
    By patangia.ramananda@gazpromneft-badra.com in forum zenon Network
    Last Post: 28th December 2015, 04:44
  2. Zenon ENERGY Edition and Runtime
    By aladimurugan in forum zenon Energy Edition
    Last Post: 17th November 2015, 02:24
  3. Zenon 7 registration error with "ZenDbSrv is running" message
    Last Post: 7th June 2013, 11:47
  4. Command function in energy edition
    By misbah in forum zenon Energy Edition
    Last Post: 28th February 2012, 11:44
  5. energy calculation in zenon 6.51
    Last Post: 2nd January 2012, 08:02
