Thread: MouseOver HoverEffect With VBA | Free Code-snippet
    14.11.2014
    Sweden
    8
    Default MouseOver HoverEffect With VBA | Free Code-snippet
    Hi Everyone!
    Since I'm doing some code-snippets I thought I share one with you!
    This simple script looks for any element on the active screen named "something_HOVER" and "theSameSomething_TRIGGER". It finds the _HOVER element and hides it when the screen is shown then if you drag your mouse over the trigger element with the same name it will un-hide the hidden element when your mouse is over the element.
    E.g:
    A400S1_HOVER <- Simple graphical element. Like a Rectangle or something
    A400S1_TRIGGER <- Combined Element named the same but _TRIGGER. This should be placed on-top of the _HOVER element and should cover the same area as the _HOVER element. But it's up to you.. It will work anyway.
    You need one more element aswell. Fill the background with another Combined Element and make sure to place it the furthest in the background.
    These 2 elements should then be connected to the VBA macros under properties "VBA Macros"
    A400S1_TRIGGER <- MouseOver: MouseOver_HoverEffect
    {Combined element in the backgrond} <- Init: Init_HideAll & MouseOver: MouseOver_Reset
    Here's a simple video tutorial on how to use it!
    And here's the code:
    ' Initiated when active screen loads background object
    ' Hides all elements with "_HOVER" in the name
    Public Sub Init_HideElements(obElem As Element)
        Dim i As Integer
        Dim objProj As Project
        Dim AllElements As Elements
        Set objProj = thisProject
        Set AllElements = objProj.DynPictures.Item(obElem.Parent.Parent.Name  ).Elements
        For i = 0 To AllElements.Count - 1
            If UCase(Right(AllElements.Item(i).Name, 6)) = "_HOVER" And AllElements.Item(i).Hide = False Then
                AllElements.Item(i).Hide = True
            End If
        Next
    ' Called when mouse moves over background element.
    ' Hides all elements with "_HOVER" in the name that are visible
    Public Sub MouseOver_Reset(obElem As Element, vPosX As Variant, vPosY As Variant)
        Dim i As Integer
            End If
        Next
    Public Sub MouseOver_HoverEffect(obElem As Element, vPosX As Variant, vPosY As Variant)
        Dim i As Integer
        Dim HoverElement As Element
        Dim stringCount As Long: stringCount = (Len(obElem.Name) - 8)
        Dim ElementName As String: ElementName = Mid$(obElem.Name, 1, stringCount)
            ' Hide all elements that is not this element
            If Left(AllElements.Item(i).Name, stringCount) <> ElementName And UCase(Right(AllElements.Item(i).Name, 6)) = "_HOVER" Then
                Set HoverElement = objProj.DynPictures.Item(obElem.Parent.Parent.Name  ).Elements.ItemById(AllElements.Item(i).ID)
                If HoverElement.Hide = False Then
                    HoverElement.Hide = True
                End If
            End If
            ' Unhide the element your mouse is over
            If Left(AllElements.Item(i).Name, stringCount) = ElementName And UCase(Right(AllElements.Item(i).Name, 6)) = "_HOVER" Then
                If HoverElement.Hide = True Then
                End If
            End If
        Next
    I've also included an export of the moduleElement file so you can simply import it to your project. You can find it under Attachements
    This is how it should look in your project:
    /NIXON
    Sith Lord @ Omexom Sweden
    03.02.2016
    Default Re: MouseOver HoverEffect With VBA | Free Code-snippet
    Quote Originally Posted by henrixon View Post
    Hi Everyone!
    E.g:
    Dim i As Integer
    End If
    Next
    Dim i As Integer
    End If
    Next
    Dim i As Integer
    End If
    End If
    End If
    End If
    Next
    that was very cool.
    I created a symbol with your whole things. but when I try to drag and drop this symbol for second one , it seems not cool. Because your code based on Element Name. so then how can we do that?
    thanks already
  1. Replies: 3
    Last Post: 21st June 2017, 11:05
  2. MouseOver fonction
    By dilem in forum VBA
    Last Post: 22nd December 2016, 14:35
  3. How to change? VBA code -> c# code
    By backjahyun in forum VSTA
    Last Post: 22nd March 2016, 07:46
  4. Replies: 6
    Last Post: 19th August 2013, 00:15
  5. Replies: 4
    Last Post: 22nd February 2012, 20:42
