Thread: Error file fpm.cmp in Zenon 6.21 SP1
    29.11.2016
    Default Error file fpm.cmp in Zenon 6.21 SP1
    I have a HMI with Zenon 6.21 SP1 installed, so i used the Zenon 6.21 SP1 Editor version to send the project to the HMI, but now the following error appears:
    ERROR: "The file 'fpm.cmp' has version 6.22 SP1 - but the project has version 6.21 SP1!"
    Anybody can help me with it?
    Best Regards
    26.02.2021
    30
    Default Re: Error file fpm.cmp in Zenon 6.21 SP1
    Did you find the solution for that?
    I'm having the same problem from version 8.20 to 10.
    My runtime is still working, but I don't know what the message means and I want to solve it just in case.
    Any help would be great.
    10.12.2007
    280
    Default AW: Error file fpm.cmp in Zenon 6.21 SP1
    fpm.cmp is the compiled file from the Production & Facility Scheduler. As this is a file which can be changed from a RT user, it is part of the files that are usually not overwritten when runtime files are created. Therefore, after converting a project into another version, the original file will be kept and when you start the RT it tells you, that this file has the wrong version.
    Have a look at the project settings " RT changeable files" and deactivate all checkboxes in the column "Do not generate and transfer". Afterwards create RT files and (re-)start RT.
    26.02.2021
    30
    Blinzeln Re: Error file fpm.cmp in Zenon 6.21 SP1
    It worked, of course...
    As I was trying to keep my recipes I wasn't deactivating those checkboxes. I figured it had something to do with it but I wasn't sure. Now I backed up my recipes and generate the changeable data. All good now.
    Thank you so much.
  1. Can not restore a *.prj file from the zenOn Explorer with the zenOn Editor
    By kyle_lee in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  2. Used keywords from Zenon language file
    By sdolnyy in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st July 2016, 07:52
  3. Installation WEB Client 6.51 SP0 "Error with writing in file: IPH_WatchDog.dll"
    By kicker in forum Smart Server & Smart Client (former Webserver & Webclient Setup)
    Last Post: 30th July 2015, 15:02
  4. CEL file date within Zenon
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 5th February 2014, 16:01
  5. I always get "Error # -60 Opening file" with the function "Read Dbase file
