Thread: Multi user variable administration
    21.01.2016
    4
    Unglücklich Multi user variable administration
    I'm using Zenon 7.5 SP0 Build2596 64Bit.
    While editing a structure data type I triggered the "variable Administration" option.
    i saw in your manual "Distributed engineering" page 20 section 8.2.1 :
    "In the special case of the variable administration the symbols are displayed slightly transparently, if the module has been checked out"
    but the manual doesn't explain how to get out from this mode, I tried the "accept changes" option but with no success.
    further more, when I try exiting the editor I get the popup windows that basically says that I didn't checked out although I accepted all the changes ..and when i press the "Accept changes" option in the window below, the program exits after several minutes.
    then I open the editor again but I'm still "stuck" in the "variable Administration" mode ����
    ------UPDATE-----
    I just Saw when I compile the project I get an error message "An error occurred while checking in element".
    02.01.2017
    Default Re: Multi user variable administration
    Quote Originally Posted by nkadishi View Post
    ------UPDATE-----
    Even though modem plugs into different types of resources like satellite, cable and fiber, they give the standard Ethernet cable output used to plug into the router IP 192.168.2.1 or a single computer and get the complete Internet connection.
  1. Versioning in the multi-user projct
    By amigo in forum zenon Service Engine Supervisor
    Last Post: 11th May 2016, 18:16
  2. Replies: 1
    Last Post: 26th April 2016, 09:19
  3. Write a complete name of the user to string variable
    Last Post: 14th October 2013, 09:11
  4. read-back user administration data by Transport
    By marchelo in forum zenon Service Engine Supervisor
    Last Post: 20th June 2010, 23:49
  5. User administration - authorizations
    By flajoso in forum zenon Service Engine Supervisor
    Last Post: 9th September 2008, 09:55
