Thread: Sicam 230 web Client - InitInstance Error
    08.11.2016
    Default Sicam 230 web Client - InitInstance Error
    Trying to use the Sicam 230 web Client (6.22 SP1) and when connecting I get an error InitInstance(): An Attempt was made to access an unnamed file past its end.  We are getting this on a machine that was running IE11 but has since been downgraded to IE10.  Does anyone have any suggestions, any help would be most welcome.
    06.02.2012
    75
    Default Re: Sicam 230 web Client - InitInstance Error
    Hi arrols,
    do you have access to our checklists on our COPA-DATA Homepage? Cause' you can find there a really good checklist about webclient with lots of input.
    Search in the Knowledge Base area for the Article-ID: 291589.
    All the best
    Xandi
    08.11.2016
    Thanks but this has not helped, does anyone else have any suggestions at all?
    06.02.2012
    75
    Did you already tried to delete the cache from the IE? - Would be also a point on the checklist.
    Beside this I wanted to ask since when the problem appears? Since the downgrade to IE10? Was the runtime ever running before without problems on IE10?
    It looks like there is somehow a corrupt file.
    Cheers
  1. SICAM 230 v7.20 runtime error
    By barry in forum zenon Supervisor
    Last Post: 28th July 2016, 15:53
  2. SICAM 230 7.0 Server can not detect Client PC
    By gorbay in forum zenon Network
    Last Post: 12th May 2015, 02:02
  3. Web Client Error
    By yitlilee in forum Webserver / Webclient Setup
    Last Post: 24th February 2015, 20:33
  4. Web client subprojects error
    By jurijcadez in forum Webserver/Webclient
    Last Post: 17th May 2012, 23:34
    Last Post: 7th August 2008, 11:57
