Thread: Scaling Problem
    26.10.2016
    Default Scaling Problem
    I have Volt and Amp data from different IEDs via Modbus TCP and IEC 61850. My problem is:
    - I need Amp (current) scaling factor to be adjustable by user input in runtime.
      There should be some code which will pop-up input screen on pressing "Settings" button and ask user to enter CT scaling ratio and scale the variable accordingly.
    I have tried by using the VBA script :
    Dim ctRatio As Integer
    thisProeject.Variables.Item("Current L1 Node 1").RangeMax = ctRatio
    And taking "ctRatio" as user input....
    But it doesn't work. However when i am in Workspace and put the "RangeMax" property of that variable to the desired scaling ratio, It does scale it well.
    But I need "adjustable scaling factor" that the runtime should ask from the user and adjust the variable accordingly.
    Please Help ..!!!
    And many thanks....
    181
    Default Re: Scaling Problem
    I think this is not possible this way. You cannot change the Scaling Range via RangeMin/Max during Runtime.
    But you can use nonlinear value adjusting with VBA and there you can use another Variable to scale.
    26.10.2016
    Thanks! I did it using Non linear value adjustment using VBA macro...
  1. Historical Trend Scaling
    By navaneet in forum zenon Supervisor
    Last Post: 7th October 2013, 15:25
  2. Auto Scaling problem
    By zenon in forum VBA
    Last Post: 20th October 2011, 15:06
  3. User managment Problem, Snapshot relativ Problem
    By jusufs in forum zenon Supervisor
    Last Post: 13th September 2010, 23:06
  4. y-scaling trendelement
    By affoltep in forum zenon Supervisor
    Last Post: 22nd July 2009, 13:38
