Thread: How to create a "Time Counter" variable?
    23.04.2009
    56
    Default How to create a "Time Counter" variable?
    As the title, How to create a "Time Counter" variable? When the event is active, the Time Counter variable runs; and when the event is inactive, the Time Counter is reset to zero.
    Peng
    Default Re: How to create a "Time Counter" variable?
    You can use the mathematic driver.
    Use the formula 'counter' in statistics.
    You need an additional function to set the Variable to zero. (function: Send value to hardware)
    Stefan
  1. Replies: 1
    Last Post: 11th December 2013, 07:15
  2. Replies: 2
  3. Replies: 5
  4. system variable "last open picture"
    Last Post: 7th April 2008, 13:50
  5. "variable image remanent" setting is not saved
