Thread: y-scaling trendelement
    affoltep Gast
    Default y-scaling trendelement
    Is it possible to change the default 0..100% scaling of the y-axis at the trendelement to a user scale e.g. 0..20m?
    Default Re: y-scaling trendelement
    Unfortunately not. The trendelement only supports the y-scale in %.
    However with zenon 6.22 if you are using a tag license, you have the ETM module in the Starter Edition included, which allows much more comprehensive trends to be displayed in the runtime, also with different user scales. (x-axis over time)
    Maybe this helps?
