Thread: Automatic line coloring (ALC) and DPI variables
    05.03.2009
    23
    Default Automatic line coloring (ALC) and DPI variables
    Hello!
    I am trying to use automatic line coloring with procedural element "Switch" and DPI variable used for this switch, but I don't have any success. When using "Switch" with BOOL variable, everithing is OK,
    Info text from the manual of ALC says that if the procedural element is in the state "undefined" or "malfunction" (DPI states "2" and "3"), this is is automatically detected. Does it mean that DPI variables are supported in ALC? If so, how?
    Best regerds,
    Gregor
    05.03.2009
    23
    Default Re: Automatic line coloring (ALC) and DPI variables
    Hello!
    Problem solved.
    In fact it was not a problem, but the precise line and object positioning. ALC works without problems with DPI signals.
    Gregor
    if you use the magnetic points while placing lines and objects, and disable the grid (use grid inactive) you get a little help from the system at connection lines with Input / Output of the combi-element
  1. Automatic Backup
    Last Post: 30th July 2019, 01:57
  2. Alarmlist text line break
    By kicker in forum zenon Supervisor
    Last Post: 28th May 2009, 08:58
  3. Trend Line
    By rloureiro in forum zenon Supervisor
    Last Post: 16th December 2008, 10:52
  4. Limiting Alarm-status line to one monitor
    By micko in forum zenon Supervisor
    Last Post: 15th September 2008, 13:20
  5. PLC Variables and Internal Variables
    By madphilly in forum Drivers
