Thread: Screen Size Problems
    10.06.2009
    13
    Default Screen Size Problems
    I've developed an application for a CE device. The screen size of the device is:
    Horizontal: 240 pixels
    Vertical: 320 pixels.
    The problem that I am having is that the CE device Taskbar remains at the top of the screen and the keyboard remain at the bottom, this causes the navigation buttons at the bottom of the screen to be hidden.
    Is there a way to disable the windows keyboard and the task bar when the zenon application is running? I still want to be able to use the keyboard and taskbar when the application is closed.
    So far I have changed multiple screen settings without any success.
    christopherpara Gast
    Default Re: Screen Size Problems
    Is it PDA that you are talking about?
    I am just interesting, do you have PDA license or CE license?
  1. Client - Server communication problems
  2. Installation on Touch Screen using DOM
    By tauhien in forum Editor and Runtime Setup
    Last Post: 26th September 2008, 02:56
  4. Screen resolution
    Last Post: 16th May 2008, 15:49
  5. screen template
    Last Post: 24th April 2008, 08:00
