Thread: communication Error again
    nahala Gast
    Default communication Error again
    Hi All,
    When I do an online change from straton,I get Communication error.The reason was quite unknown to me. First time when it happened I restarted my computer.Thus it was solved.
    this time even if I restarted the problem is still there.
    Please help me with your inputs
    Thank you in advance.
    Nahala
    Default Re: communication Error again
    Hi Nahala,
    I don't have an immediate idea what could cause this behaviour. But maybe someone else in this forum has?
    I presume that you activated the "online change" option in your straton project settings, you have enough "spare" memory reserved for these changes, and did not make any "illegal" changes?
    How to activate online change for the straton project, and which changes are allowed and which are unsafe, and how to find out how much memory is left for online changes, can be found in the straton workbench documentation, in the chapter
  1. Client - Server communication problems
  2. Communication Error!!
    Last Post: 30th April 2009, 09:33
  3. Communication does not work
    By markclemens in forum Drivers
    Last Post: 28th August 2007, 13:49
