Thread: I/O Devices
    nahala Gast
    Default I/O Devices
    Hi All,
    I want to know more about I/O Devices.Is it the interface between Straton and physical I/Os.From Straton handbook I understood , these I/O s can be made virtual for simulation purposes.I made it virtual by pressing space bar.
    Can these inputs be made available for zenon like other inputs ? if possible how to do that?
    How these I/Os are supposed to be used?
    Thanks & Regards,
    Nahala
    Default Re: I/O Devices
    straton can also use certain I/O boards in the local PC to communicate. Click on the "Open I/Os" icon, double click on one of the empty slots, select your I/O board, (e.g. "WinCon iDIO16") and your I/Os will be available in straton.
    For these variables, an alias can be defined. If an alias is defined, and the option "embed symbol" and the profile "straton" are set, these variables would also be available in zenon.
  1. Chinese language on CE devices
    Last Post: 13th April 2010, 23:50
  2. Network doesn't work on Windows CE devices
    Last Post: 28th August 2007, 12:11
  3. GIF images on Windows CE devices
    Last Post: 27th August 2007, 09:03
  4. Display trend on Windows CE devices
    Last Post: 27th August 2007, 08:57
  5. Cannot browse Profinet devices
    By markusw in forum straton / zenon Logic
    Last Post: 21st August 2007, 09:06
