Thread: SQL error when I try the archive server function
    23.04.2009
    56
    Default SQL error when I try the archive server function
    Now I am trying the archive server function, but I met a SQL error when I try to make a 'Picture Switch' function which is to load the Control picture..
    Precisely, I followed the "Archive_Server.pdf" in the "Tutorials" documents. I have created a basic archive, and a picture Archive Revision (with defaut control elements).
    And then, I try to make a 'Picture Switch' function to load the picture Archive Revision. But when I click the button 'OK', there is a message in my "Output Window" view :
    Error ExecuteCommand :'Recordset could not be opened Errorcode:112' FillDataReader Error!
    Error ExecuteCommand SQL:'INSERT INTO [Function] ([SC_State],[SC_IDClient],[SC_CTime],[SC_MTime],[Object],[Name],[Type],[ModifiedCnt]) VALUES (?,?,?,?,?,?,?,?);
    SELECT @@IDENTITY AS 'ID';'!
    Error ExecuteScalar from Project:61BR! Error:Failed to insert record Errorcode:110 !
    And after that, although this picture switch function is created, but I can not use it at all.. How can I resolve this problem ?
    Default Re: SQL error when I try the archive server function
    a very rare sporadic issue is known, when switching network connections (unplug / plug the network cable) or in combination with the sleep / standby mode under very special circumstances, that the local network connections are somehow reset. It can happen, that e.g. there is a connnection from process A port x to the local listening socket y of process B (as seen from process A), but at process B this connected process is not visible)
    In this situation, it can happen that the editor looses the connection to the SQL server. When you restart the editor, you will probably see that the function is not available anymore.
    Please restart the editor and try and re-create the picture switch function. This should then also work in the runtime!
    23.04.2009
    56
    Thank you a lot for your answer. The problem I met is exactly the same as your description.
    I appreciate a lot your product-support service !
    Quote Originally Posted by MarkClemens View Post
  1. Replies: 2
  2. Archive SE seems very limited
    Last Post: 25th September 2008, 14:43
  3. Archive Server Problem
    By rloureiro in forum zenon Supervisor
    Last Post: 28th August 2008, 14:56
  4. How does the batch archive gets its name?
    By bernhards in forum zenon Pharma Edition
    Last Post: 21st August 2007, 08:59
  5. On opening the archive MDI window an error appears!
    Last Post: 17th August 2007, 13:11
