Thread: startup problem
    Default startup problem
    hello,
    i recently encoutered a problem in starting the runtime
    i use to run the "zenKeyBlock.exe" which was added to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
    after adding some other programs on the pc the runtime would not start anymore and gave me the following error
    and after the runtime shut down, but after complete start of the PC if i manually start zenKeyBlock.exe the runtime would starrt
    so is there a way to delay the zenkeyblock so it may run after zenAdminSrv ?
    Best Greetings
    Default Re: startup problem
    take a look at this post:
    http://www.copadata.com/forums/showthread.php?t=257
    using the vbscript and starting the zenkeyblock.exe instead of the zenrt32.exe should solve your problem.
  1. Web Client 620 crashes on startup.
    By zw1 in forum Editor and Runtime Setup
    Last Post: 20th April 2009, 14:23
  2. when I start the editor from the startup tool nothing happens
    Last Post: 3rd January 2008, 08:51
  3. Error message at Runtime Startup
    By martinw in forum zenon Supervisor
    Last Post: 20th August 2007, 08:07
  4. The zenOn Editor crashes at startup!
    Last Post: 13th August 2007, 16:16
