Thread: Screen resolution and Windows CE
    scotttee Gast
    Default Screen resolution and Windows CE
    I developing an application for a customer who has a "Base" application I am to start developing from. This "Base" app has a resolution set for 1280x768. The Base is mainly used for the PC platform, but my application is targeted for Windows CE. Will the "Adjust Monitor Resolution" setting work in this case or do I have to change the Base res to match the CE device?
    Thanks,
    Scott
    Default Re: Screen resolution and Windows CE
    generally the "adjust monitor resolution" does work. The screens are scaled to match the target resolution.
    If it will work in your situation depends on two things. One is how the project is designed (what fonts are used, if e.g. bitmap buttons are used etc.) and another is the difference in screenresolution.
    With very big differences, e.g. 1280x1024 and a CE device with 320x240, things might be scaled in a way that it e.g. is hard to recognize text because it is so small. If your CE device has a screenresolution of e.g. 800x600, it might work well enough.
  1. Replies: 1
    Last Post: 17th December 2008, 09:07
  2. Installation on Touch Screen using DOM
    By tauhien in forum Editor and Runtime Setup
    Last Post: 26th September 2008, 02:56
  3. Screen resolution
    Last Post: 16th May 2008, 15:49
  4. screen template
    Last Post: 24th April 2008, 08:00
  5. Monitor administration and screen resolution
