Thread: can't create new project in zenon editor
    shahramkh59 Gast
    Default can't create new project in zenon editor
    I installed zenon 6.22 sp0 and when i want to create new project in zenon editor display this error for me:don't create new project 'choose name'
    why this error is displayed?and how i could solve this problem and create new project?
    Default Re: can't create new project in zenon editor
    Maybe there is already another project with the same name in the workspace?
    You can't create a project in a workspace with a name which already exists.
    Can you load existing projects or restore a project backup? Maybe there is an issue with the database connection to the SQL server.
    Are there any previous versions of zenon installed on this PC?
    shahramkh59 Gast
    Quote Originally Posted by MarkClemens View Post
    yes,i can.yes,i installed this version of program less than one week ago.
    i can create workspace but can not create new project
    in the %CD_PROGRAMDATA6220%LOG directory (for zenon 6.22 SP0, this points to "c:\documents and settings\all users\application data\copa-data\zenon622\log" on Windows XP and "c:\programdata\copa-data\zenon622\log" on Windows Vista) there are logfiles from the diagnosis server. Whenever there is an error in zenon, either in the editor, or in the runtime, or in communication to the PLC, logging information is stored here by the diagnosis server.
    You can try and analyze the logfiles yourself, using the diagnosis viewer, which can be found in the COPA-DATA start menu in the tools section, or zip and upload the logfiles here, for us to take a look at it.
  1. Replies: 5
  2. zenOn-Editor 6.22 SP0 Build 3 beendet sich sofort nach dem Starten
    By maerz@staudinger-est.de in forum zenon Supervisor
    Last Post: 19th September 2008, 21:17
  3. Replies: 0
  4. Replies: 0
    Last Post: 20th August 2007, 14:14
  5. The zenOn Editor crashes at startup!
    Last Post: 13th August 2007, 16:16
