I have imported a VBA wizard in the zenOn editor, and it states success in the output window, however it does not show up in the VBA wizard list (Alt+F12). What am I doing wrong?
Probably the wizard uses a file or an activeX control which is either not linked or not active as a reference in the VBA editor. Please open the VBA editor and see if you can compile the zworkspace.vba. If this is not possible due to missing references, the wizard will also not show up in the wizard dialog. Please check the references in the extras menu of the VBA IDE, or consult the person you received the VBA wizard from.
