Thread: Templates and pictures
    nahala Gast
    Default Templates and pictures
    Hi All,
    I am a new user of zenon .I have a doubt regarding pictures.
    I wanted to create a User Interface.I created 3 templates for its header ,process picture and bottom area. I created 3 pictures(picture0,picture1,picture3) for each templates. I need to get all the three pictures together.
    Now I get only one of the pictures while running. The one I assigned in the start picture property of Project.How to make all pictures come at same time?
    Thank you in advance.
    Nahala
    881
    Default Re: Templates and pictures
    You can use i.e. the Autostart-Script in which you would add all necessary "picture-switch" functions to the pictures
    Please take a look into the help documentation about this:
    Manual -> Scripts
    If you are starting to work with zenOn take a look into the "Tutorials"
    -> First Steps
    If you want to have a project generated automatically take a look to the "Project Wizard"
    -> in the zenOn Editor press "ALT+F12", select category "Project" and the the wizard "Project-Wizard"
    Herbert Oberauer
    Additionally to the zenon scripts there is the possibility to use the "start function" settings of a picture to sequentially start the pictures needed.
    ATTENTION:
    But be careful with this possibility a loop is easily created but hard to find!
    The zenon function linked as "start function" to a picture is carried out when the picture has been started.
    nahala Gast
    Hi herberto/wolfgangm,
    Thanks very much for your kind reply. It worked for me.
    Regards
    Nahala
  1. Update pictures with VBA
    By fabios in forum VBA
    Last Post: 21st July 2008, 09:25
  2. Slow handling of objects in very large pictures
    Last Post: 29th October 2007, 14:00
  3. Help making some pictures
    By ale_001 in forum zenon Service Engine Supervisor
    Last Post: 23rd October 2007, 14:28
