Can someone explain how the message dynamic element works?
It uses specially formatted text file to display a message, right? How is the text file formatted?
Thanks.
Thanks.
please also check the documentation on the message element (in the online help, chapter "Pictures" -> Picture Elements -> Picture Elements -> Message)
the seperator for the unicode text file, is a "|" The file must be a unicode text file.
So a file with three columns and two rows could look like this:
Column1Row1|Column2Row1|Column3Row1
Column2Row2|Column2Row2|Column3Row2
What is it exactly what you want to display in your picture?
A text message that indicates the status of a dryer: Online, depressurizing, failure to shift...
I looked at the documentation for the message display. It's not very helpful. An example would be good.
Thanks.
the message element is one possibility, using limits resp. a reaction matrix is a different possibility. Here you define the values with the corresponding text, and a "link text" element in the picture.
Also with the combi-element you can display different texts depending on a value.
Also with the combo- /listbox you can display different texts depending on a value.
There are several other possibilities, all of them will probably do what you would want to achieve. Depending on your configuration, you might want to choose one of the methods above.
Yes, the combi-element seems like the best route.
Thanks for your help Mark.
Is there a way to embed a CR (carriage return) in the Status Text field of the combi-element?
I'd like to display something like:
Step 1
Left Tower On-line
Depressurize Right Tower
Thanks.
the "\n" (\ is an escape character) can be used to continue on a new line, in th combi-element.
so the statustext in the combi-element would look like this:
Step1\nLeft Tower On-line\nDepressurize Right Tower
