Thread: Status variable for alarm areas
    Default Status variable for alarm areas
    6.22 SP0: when I want to insert a variable for an alarm area as status variable,
    zenon seeks for a boolean variable, but it must be a byte one.
    So the solution is to change the variable to boolean, insert it and
    change back to byte.
    Ist this bug solved in SP1 anyhow?
    Jürgen Berger
    Default Re: Status variable for alarm areas
    Yes this has been a bug which is solved and available with the SP1 of zenon 6.22!
    Your approach to circumvent the situation was pretty perfect.
    Daumen hoch AW: Status variable for alarm areas
    Thanks for quick reply!
    Jürgen Berger
  1. Value, Time-Stamp and status with allocations
    Last Post: 12th May 2021, 08:43
  2. Alarm Status Line and Alarm List
    By tomaslipa in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  3. Limiting Alarm-status line to one monitor
    By micko in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 15th September 2008, 13:20
  4. Change variable status
    By brada in forum VBA
