Thread: Popup variables
    dietersar Gast
    Default Popup variables
    I'm using the same popup picture for the same function with different variables. Depending on the passed variables on the popup, I'll have to do something with them.
    How can I get the variable names from the popup picture and how can I get the name of the calling function in VBA?
    Thanks.
    Default Re: Popup variables
    I'm not 100% sure what you mean.
    If you have a function which calls a pciture and substitutes the variables in the picture with other variables, by means of replacing variables or functions hard-coded, you can access the Dynproperties "PictSwitch.SubstiVar[0].Source" and "PictSwitch.SubstiVar[0].Destination" in VBA.
    If you are using the replace indices functionality, you can get the variable object of the first index variable through the Dynproperties "PictSwitch.IndexVar[0].Title"
    The replace string for replacing indices can be read through the DynProperties "PictSwitch.IndexSubstitution[0].Source" and "PictSwitch.IndexSubstitution[0].Destination"
    Note, that e.g. "PictSwitch.SubstiVar[-1].Source" returns the amount of variables in the substitution, so you can build e.g. a For Next loop.
    regarding the function, you could instead of the function, execute a VBA macro, which, depending on the name of the button, executes a specific function.
    If you tell me more about what exactly it is that you want to achieve, I might be able to provide another, more effective solution
    24.04.2012
    17
    Beitrag Re: Popup variables
    Dear Mark,
    i try to create a function using VBA with indexing method.
    here my cade is
    Private Sub GetorCreateFunction()
        Dim FunctionName As String
        Dim Rtfn As RtFunction
        Dim PictureName As String
        FunctionName = "testfn"
        PictureName = "1CM_01_Win_3S_BS"
        Set Rtfn = thisProject.RtFunctions.Item(FunctionName)
        If Rtfn Is Nothing Then
            Set Rtfn = thisProject.RtFunctions.Create(FunctionName, tpPicture)
        End If
        With Rtfn
            .DynProperties("PictSwitch.Picture") = PictureName
            .DynProperties("PictSwitch.IndexVar[0].Title") = "0ST_Win_3S_BS_Sts1_Indx"
            .DynProperties("PictSwitch.IndexSubstitution[0].Source") = "sys_Win_3S_BS_Sts1"
            .DynProperties("PictSwitch.IndexSubstitution[0].Destination") = "{X01}"
        End With
    this script is creating only the function with out indexing.
    i'm using Zenon7.0
    kindly check and do the needful
    Thanks&Rgds,
    Paruvathakumar
    881
    qoute:
    you can not create functions, screens, elements, ... in the zenon runtime
    you can modify existing functions within the zenon runtime via vba/vsta before executing
    regards,
    herbert
    24.04.2012
    17
    i'm executing the above function in Editor only.
    the above script is creating the RtFunction with out indexing.
    Thanks&Rgds,
    Paruvathakumar
    881
    thisproject = VBA code within the project for the zenon Runtime
    MyWorkspace = zenon Editor
    Please check the help documentation at
    Manual -> Programming interfaces -> Object model -> RtFunction
    -> at the bottom of that page you can find an example how to modify an existing function within the zenon Runtime
    Manual -> Programming interfaces -> Object model -> RtFunctions
    -> examples which show how to create functions via VBA in the zenon Editor
  1. Replies: 2
    Last Post: 17th December 2008, 09:09
  2. Replies: 1
    Last Post: 17th December 2008, 09:07
  3. PLC Variables and Internal Variables
    By madphilly in forum Drivers
