Thread: variable type time didn't appear in zenon
    Default variable type time didn't appear in zenon
    I am trying to use a variable type time in straton but this variable didn’t appear in zenon editor,
    Note that all other type appear without problem
    05.09.2007
    8
    Default Re: variable type time didn't appear in zenon
    Quote Originally Posted by johnny View Post
    Hi johnny,
    The data type TIME is not supportet by the so called integrated solution. Therefore this variable doesn't appear in zenon Editor.
    In order to exchange time values between straton and zenon just convert (any_to_*) the value to e.g. DINT.
    All the best
    Quote Originally Posted by juergenresch View Post
    Hi johnny,
    All the best
    hii,
    thank you very much for your reply
    and in zenon editor how can convert type DINT for example to type time
    05.09.2007
    8
    hii,
    Hi Jonny,
    You can convert the data type DINT into TIME format via VBA.
    Another possibility is to modyfy the DINT-value in straton in order to be able to show h, min, sec in zenon. Like this:
    diTime := any_to_dint (tTimeBasic);
    rTimeS := trunc( (any_to_real(diTime)/1000.0 )); //truncate millisconds
    diTimeSec := any_to_dint (rTimeS) - diTimeMin * 60 - diTimeHr * 3600; //calculation of seconds
    diTimeMin := (any_to_dint (rTimeS / 60.0)) - diTimeHr * 60; //calculation of minutes
    diTimeHr := any_to_dint (rTimeS / 3600.0); //calculation of hours
    //with that you can show three numerical values in zenon
    strTime := any_to_string(diTimeHr) + 'h' + any_to_string(diTimeMin)
    + 'min' + any_to_string(diTimeSec) + 's'; //concatanate in a string
    //with that you can show the time in a Link text element in zenon
    With these variable definitions:
    VAR
    tTimeBasic : TIME := T#12h13m14s ;
    strTime : STRING(15) ;
    rTimeS : REAL ;
    diTimeSec : DINT ;
    diTimeMin : DINT ;
    diTimeHr : DINT ;
    diTime : DINT ;
    END_VAR
    Jürgen
  1. Variable von Excel über DDE-Treiber in Zenon darstellen
    By axel_sch in forum zenon Supervisor
    Last Post: 26th November 2008, 08:56
  2. compare time variable with system time
    By flajoso in forum VBA
  3. Processor type
    Last Post: 19th September 2007, 16:15
  4. more than one driver of same type
    Last Post: 18th September 2007, 07:36
