Thread: Limit Text - Display ID or Name of variable
    craigdouglas Gast
    Default Limit Text - Display ID or Name of variable
    I have many pages with the same layout and I need to be able to display the limit text (I can do this already) and the ID of the variable. I thought I'd be able to create a link text and just tell it to display the ID of the variable rather than the limit but I can't find the option.
    The only way I can think of is to embed the ID within the limit text itself. Is there a better way to do this like what I initially thought above?
    Default Re: Limit Text - Display ID or Name of variable
    you can display either the name or the identification of a variable linked to the combi-element with a specific syntax. Set the combi-element to "statustext & symbol" and use the following syntax at the default state
    %n - shows the variablename
    %n,1,2 - shows the variablename from position 1 for 2 characters
    %N - shows the variablename
    %N,3,2 - shows the variablename excluding the first 3 leading characters and excluding the traling 2 characters
    %l - shows the variable identification
    %l,1,2 - shows the variable identificationzeigt from position 1 for 2 characters
    %L - shows the variable identification
    %L,3,2 - shows the variable identification excluding the first 3 leading characters and excluding the traling 2 characters
    craigdouglas Gast
    Perfect!
    Thanks Mark!
    craigdouglas Gast
    Why can't I do a language table lookup in the combi element using:
    @%n
    When I have the language table set up with variable names as keywords.
    It just displays "%n"
    you will find that with the @ in front of %n, the %n will turn in a normal keyword for the language change.
    generally, the variable name must be unique and language change is not possible with the variable name.
    when you've tried with the identification and %l, you will see, that the text also displayed as "@variable identification" in the combi-element, instead of the translated text. The reason is, that the %l is a special keyword for the combi element and displays the variable name or identification "as is", as it is possible with the syntax to display only parts of the variable names / identification.
    What is it, that you exactly want to achieve? Maybe there is another solution
    craigdouglas Gast
    I've sent detailed information about my problem via support ticket [TAT081202JYVP]
  1. Changing alarm text.
    Last Post: 20th October 2008, 07:23
  2. Edit Variable limit (Delay)
    By rloureiro in forum VBA
    Last Post: 12th September 2008, 09:25
  3. display last open picture
    By dak2483 in forum zenon Operator
    Last Post: 5th September 2008, 18:57
  4. Display Text Value
    By lengele in forum zenon Supervisor
    Last Post: 18th December 2007, 13:50
  5. Display trend on Windows CE devices
    Last Post: 27th August 2007, 08:57
