Thread: Within the zenOn WebServer Console the buttons are greyed!
    Default Within the zenOn WebServer Console the buttons are greyed!
    The status of the zenOn Webserver is "not installed" and the webserver service can not be started out of the Webserver Console, the start and stop buttons are greyed out! Does this mean the zenOn WebServer is not installed correctly?
    No, normally the zenOn WebServer is installed correctly, but be aware that you need to be "Power User" or "Administrator" to be able to start services. This is rather a restriction of the operating system then from zenOn!
    Default Re: Within the zenOn WebServer Console the buttons are greyed!
    by executing the following commands from the command prompt with Administrator rights in the directory where the zenon webserver was installed, you can fix this issue:
    "zenwebsrv -unregsrv"
    "zenwebsrv -service"
    "net start zenwebsrv"
    make sure, the "services window" is not open during the registration in the command prompt.
