Thread: zenOn error
    Default zenOn error
    hello
    im using zenOn 6.22 SP0 Build0 and when I close the curves dialog in an Extended Trrend page in zenOn runtime it gives me an error and shut down.
    is it a version problem?
    Default Re: zenOn error
    ok solved the problem but i think there is a bug in zenon
    the curve list should be in the form when calling the curve dialog box with the curve button , i had erased the curve list from the from before , but now when i added it the error is gone
    879
    This is a known defect in zenOn 6.22 SP0 B0 and has been fixed with Build6. The problem was a forground/background behaviour of the Curves-Dialog when closing it (clicking "OK").
