Thread: Create AlarmClasses / AlarmGroups / AlarmAreas via VBA
    882
    Default Create AlarmClasses / AlarmGroups / AlarmAreas via VBA
    With zenOn versions >= 6.22 it is possible to create AlarmClasses / AlarmGroups / AlarmAreas via VBA:
    Private Sub CreateAlarmClassGroupArea()
    Dim nClassCurrentAmount As Integer
    Dim nGroupCurrentAmount As Integer
    Dim nAreaCurrentAmount As Integer
    Dim nLastColor As Double
    Dim strLastClassName As String
    Dim strLastGroupName As String
    Dim strLastAreaName As String
    'Dynamicaly create a new Class
    nClassCurrentAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmClasses")
    If (nClassCurrentAmount > 0) Then
        nLastColor = MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClassCurrentAmount - 1)) & "].Color")
    End If
    MyWorkspace.ActiveDocument.CreateDynProperty ("AlarmClasses")
    strLastClassName = "ClassName" & Trim(Str(nClassCurrentAmount + 1))
    MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClassCurrentAmount)) & "].Name") = strLastClassName
    MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClassCurrentAmount)) & "].Description") = "ClassText" & Trim(Str(nClassCurrentAmount + 1))
    MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClassCurrentAmount)) & "].Color") = nLastColor + 1000
    'Dynamicaly Create a new Group
    nGroupCurrentAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmGroups")
    If (nGroupCurrentAmount > 0) Then
        nLastColor = MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGroupCurrentAmount - 1)) & "].Color")
    End If
    MyWorkspace.ActiveDocument.CreateDynProperty ("AlarmGroups")
    strLastGroupName = "GroupName" & Trim(Str(nGroupCurrentAmount + 1))
    MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGroupCurrentAmount)) & "].Name") = strLastGroupName
    MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGroupCurrentAmount)) & "].Description") = "GroupText" & Trim(Str(nGroupCurrentAmount + 1))
    MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGroupCurrentAmount)) & "].Color") = nLastColor + 1000
    'Dynamicaly Create a new Area
    nAreaCurrentAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmAreas")
    MyWorkspace.ActiveDocument.CreateDynProperty ("AlarmAreas")
    MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCurrentAmount)) & "].Name") = "AreaName" & Trim(Str(nAreaCurrentAmount + 1))
    MyWorkspace.ActiveDocument.CreateDynProperty ("AlarmAreas[" & Trim(Str(nAreaCurrentAmount)) & "].Items")
    MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCurrentAmount)) & "].Items[0].StatusVar") = 4
    MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCurrentAmount)) & "].Items[0].AlarmVar") = 5
    MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCurrentAmount)) & "].Items[0].QuitVar") = 6
    MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCurrentAmount)) & "].Items[0].ClassName") = strLastClassName
    Below you can find how to read AlarmClasses / AlarmGroups / AlarmAreas:
    Private Sub GetAlarmClassGroupArea()
    Dim nCounter As Integer
    Dim nGrpCounter As Integer
    Dim nGrpAmount As Integer
    Dim nClsCounter As Integer
    Dim nClsAmount As Integer
    Dim nAreaCounter As Integer
    Dim nAreaAmount As Integer
    Dim nAreaItemAmount As Integer
    Dim nAreaItemCounter As Integer
    nClsAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmClasses")
    nAreaAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmAreas")
    nGrpAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmGroups")
    If (nGrpAmount > 0) Then
        For nGrpCounter = 0 To nGrpAmount - 1
            Debug.Print "GrpName:" & MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGrpCounter)) & ".Name")
            Debug.Print "GrpText:" & MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGrpCounter)) & ".Description")
            Debug.Print "Color:" & MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGrpCounter)) & ".Color")
            Debug.Print "Number:" & MyWorkspace.ActiveDocument.DynProperties("AlarmGroups[" & Trim(Str(nGrpCounter)) & ".Id")
        Next
    End If
    If (nClsAmount > 0) Then
        For nClsCounter = 0 To nClsAmount - 1
            Debug.Print "ClsName:" & MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClsCounter)) & ".Name")
            Debug.Print "ClsText:" & MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClsCounter)) & ".Description")
            Debug.Print "Color:" & MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClsCounter)) & ".Color")
            Debug.Print "Number:" & MyWorkspace.ActiveDocument.DynProperties("AlarmClasses[" & Trim(Str(nClsCounter)) & ".Id")
        Next
    End If
    If (nAreaAmount > 0) Then
        For nAreaCounter = 0 To nAreaAmount - 1
            Debug.Print MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCounter)) & ".Name")
            nAreaItemAmount = MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCounter)) & ".Items")
            If (nAreaItemAmount > 0) Then
                For nAreaItemCounter = 0 To nAreaItemAmount - 1
                    Debug.Print MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCounter)) & ".Items[" & Trim(Str(nAreaItemCounter)) & "].ClassName")
                    Debug.Print MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCounter)) & ".Items[" & Trim(Str(nAreaItemCounter)) & "].StatusVar")
                    Debug.Print MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCounter)) & ".Items[" & Trim(Str(nAreaItemCounter)) & "].AlarmVar")
                    Debug.Print MyWorkspace.ActiveDocument.DynProperties("AlarmAreas[" & Trim(Str(nAreaCounter)) & ".Items[" & Trim(Str(nAreaItemCounter)) & "].QuitVar")
                Next
            End If
        Next
    End If
    15.11.2011
    7
    Default AW: Create AlarmClasses / AlarmGroups / AlarmAreas via VBA
    I want to access to the alarmclass by name in the runtime - is this possible?
    josefm Gast
    Default Re: AW: Create AlarmClasses / AlarmGroups / AlarmAreas via VBA
    Hi lew,
    please find this information in the help topic "Manual -> Programming interfaces -> Object model -> AlarmItem -> AlarmClass". To access alarms by name is not possible. You can only read the alarm class of an alarm during the runtime.
    What is your need to access the alarm class by name?
    Best regards
  1. Create a function for a trend picture
    By robertf in forum VBA
    Last Post: 4th October 2018, 14:33
  2. Create an Element
  3. How to create a new MACRO?
    By matholton in forum VBA
