Thread: create a recipegroup and recipe with "link to PV"
    Default create a recipegroup and recipe with "link to PV"
    How do I create a recipegroup, then link a variable, then create a recipe, and then change the type of the variable to "link to PV" and set the target variable?
     Sub create_rgm_rec_alloc()
    Dim myRGMgroup As RGMRecipeGroup
    Dim myRGMrecipe As RGMRecipe
    Dim myRGMvar As RGMRecipeVar
    Dim myRGMvalue As RGMRecipeValue
    Dim mySourceVar As Variable
    Dim myTargetVar As Variable
    Set mySourceVar = MyWorkspace.ActiveDocument.Variables.Item("mySource")
    Set myTargetVar = MyWorkspace.ActiveDocument.Variables.Item("myTarget")
    Set myRGMgroup = MyWorkspace.ActiveDocument.RGMGroups.Item("hugo")
    If myRGMgroup Is Nothing Then
        'create the group
        Set myRGMgroup = MyWorkspace.ActiveDocument.RGMGroups.CreateGroup("hugo")
        'and set it to nothing and set it again, in order to create a recipe
        Set myRGMgroup = Nothing
    End If
    If Not myRGMgroup Is Nothing Then
        myRGMgroup.AddVariable myTargetVar
    End If
    Set myRGMrecipe = myRGMgroup.RecipeItem("abc")
    If myRGMrecipe Is Nothing Then
        Set myRGMrecipe = myRGMgroup.CreateRecipe("abc")
        Set myRGMrecipe = Nothing
    End If
    If Not myRGMrecipe Is Nothing Then
        myRGMrecipe.ValueItem(0).DynProperties("Type") = 9
        myRGMrecipe.ValueItem(0).DynProperties("SourceVar") = mySourceVar
    End If
    'do not forget to save! otherwise changes are lost.
    myRGMrecipe.Save
    terrancelee Gast
    Default AW: create a recipegroup and recipe with "link to PV"
        'create the group
    End If
    End If
    End If
    End If
    myRGMrecipe.Save
    Vielen Dank für detaillierte Code. Ich weiß, Thread ist etwas alt, aber ich suchte ihn für eine Weile .. SO nochmals vielen Dank.
  1. I always get "Error # -60 Opening file" with the function "Read Dbase file
    By wolfgangm in forum zenon Service Engine Supervisor
  2. Neuer Button "Alle aktivieren" (Variablen)
    By maerz@staudinger-est.de in forum zenon Service Engine Supervisor
    Last Post: 24th September 2008, 11:13
  3. action "COMMAND" at the dynamic element not visible
    Last Post: 16th May 2008, 06:53
  4. Replies: 2
  5. "variable image remanent" setting is not saved
