Showing results 1 to 9 of 9
Thread: Create a function for a trend picture
    robertf Gast
    Default Create a function for a trend picture
    Here is a basic sample how to create a function for an extended trend picture...
    [highlight=vb]
    'Create Function for TREND - PICTURE
    Sub CreateTrendFunction()
    Dim zPIC As DynPicture
    Dim zFCT As RtFunction
    Dim i As Integer
    Set zPIC = MyWorkspace.ActiveDocument.DynPictures.Item("TREND")
    'Create new function
    Set zFCT = MyWorkspace.ActiveDocument.RtFunctions.Create("picTREND", tpPicture)
    'function settings...
    With zFCT
    .DynProperties("Picture") = zPIC.Name
    i = .DynProperties("PictFilter[-1]")
    If i = 0 Then .CreateDynProperty "PictFilter"
    .DynProperties("PictFilter[0].RefreshRate") = 1
    .DynProperties("PictFilter[0].Name") = "WIZARD TREND"
    .DynProperties("PictFilter[0].IsArchive") = False
    .DynProperties("PictFilter[0].IsXAxis") = False
    'Add 3 CURVES
    For i = 0 To 2
    n = .DynProperties("PictFilter[0].Curve[-1]")
    If n <= i Then
    'create CURVE SubItem if needed
    .CreateDynProperty ("PictFilter[0].Curve")
    .CreateDynProperty ("PictFilter[0].Curve[" & i & "].VarInfo")
    .CreateDynProperty ("PictFilter[0].Curve[" & i & "].YAxe")
    .CreateDynProperty ("PictFilter[0].Curve[" & i & "].YAxe[0].Scale")
    End If
    'change curve settings
    .DynProperties("PictFilter[0].Curve[" & i & "].GraphName") = "MyVariable_" & i
    .DynProperties("PictFilter[0].Curve[" & i & "].HasYAxis") = True
    .DynProperties("PictFilter[0].Curve[" & i & "].IsShow") = True
    .DynProperties("PictFilter[0].Curve[" & i & "].IsInterpolation") = True
    .DynProperties("PictFilter[0].Curve[" & i & "].VarInfo.VarName") = "MyVariable_" & i
    .DynProperties("PictFilter[0].Curve[" & i & "].VarInfo.Channel") = "MyVariable_" & i
    .DynProperties("PictFilter[0].Curve[" & i & "].VarInfo.Variable") = "MyVariable_" & i
    .DynProperties("PictFilter[0].Curve[" & i & "].VarInfo.VarMaxValue") = 1000
    .DynProperties("PictFilter[0].Curve[" & i & "].VarInfo.VarMinValue") = 0
    .DynProperties("PictFilter[0].Curve[" & i & "].YAxe.IsAutoScale") = False
    .DynProperties("PictFilter[0].Curve[" & i & "].YAxe.Color") = vbBlack
    .DynProperties("PictFilter[0].Curve[" & i & "].YAxe.Scale.ScaleTop") = 1000
    .DynProperties("PictFilter[0].Curve[" & i & "].YAxe.Scale.ScaleBotton") = 0
    Next i
    'filter settings (relative time 5 minutes)
    .CreateDynProperty ("PictFilter[0].TimeAxe")
    .DynProperties("PictFilter[0].TimeAxe.OldDiff") = 3600
    .DynProperties("PictFilter[0].TimeAxe.TimeFilter.Options") = 65535
    .DynProperties("PictFilter[0].TimeAxe.TimeFilter.ARVTime1") = CDate(25569.0451388889) '("01.01.1970 01:05:00")
    .DynProperties("PictFilter[0].TimeAxe.TimeFilter.ARVTime2") = CDate(25569.0416666667) '("01.01.1970 01:00:00")
    End With
    [highlight]
    tskotvig Gast
    Default Re: Create a function for a trend picture
    Zenon Vs. 6.22 SP1 Build 5
    I have a dynamic trend much like this one, but with a possibility of absolute time and relative.
    it works on my pc with no complaints (XP proffesional 32bit),
    But when installing it on a customers pc (same OS) (Status via remote transport: Compability guaranteed), the time settings from the ARV Function diagram settings is present no matter what in relative time....
    Any idea what this might be?
    Code:
    'Absolute time (works)
    If nRelTime = 0 Then
    dStart = CDate(dtSTART_DATE_TIME)
    dStop = CDate(dtEND_DATE_TIME)
    .DynProperties("PictFilter[0].TimeAxe.TimeFilter.ARVTime1") = dStart '("01.01.1970 01:05:00")
    .DynProperties("PictFilter[0].TimeAxe.TimeFilter.ARVTime2") = dStop '("01.01.1970 01:00:00")
    'Stop
    Else
    'relative time (does not work)
    If nRelTime = 1 Then
    dStop = CDate(DateSerial(1970, 1, 1) + TimeSerial(1, 0, 0))
    dStart = DateAdd("s", DateDiff("s", dtSTART_DATE_TIME, dtEND_DATE_TIME), dStop)
    Stop
    End If
    maybe the other PC is using a different time zone? (GMT +2 or higher)
    There may be issues when using a constant datetime like "01.01.1970 01:05:00", when converting or working with the datetime type.
    The system may assume this is UTC, tries to convert it to local time (which could result in 31.12.1969 ... , when you are GMT+2 or higher) which is not valid.
    tskotvig Gast
    Thanks for the quick reply.
    I am in South Korea right now and i do have set the korea timezone, and my PC is on gmt+1.
    I will to change the timezonetry as soon as i get to the factory today.
    Once again thank you very much!
    05.03.2010
    3
    Quote Originally Posted by robertf View Post
    [highlight=vb]
    Dim i As Integer
    With zFCT
    'Add 3 CURVES
    For i = 0 To 2
    If n <= i Then
    End If
    Next i
    End With
    [highlight]
    Sor but i couldnt understand what thıs gunctıon does and how i can use it. Can u explain it? thank you
    880
    Of course this only works in the zenon editor (not in the runtime)
    -> a picture of the type "Extended Trend" with the name "TREND" has to be created before
    -> the variables MyVariable_1, MyVariable_2, MyVariable_3 have to be created before
    21.02.2018
    3
    Default AW: Create a function for a trend picture
    Hallo zusammen,
    ich habe versucht den Code in VSTA umzusetzen.
    Leider funktioniert der VBA Code in VSTA nicht.
    Wie kann ich die Anzahl der Kurve in VSTA ermitteln?
    Gre
    iconix
    31.03.2008
    4
    i have zenOn 7.60 and i also want to create a function to a extendet Trend Picture.
    I can create the function and die pictfilter
    but wenn i want to create a curve (.CreateDynProperty ("PictFilter[0].Curve")) i get the VBA error:
    Runtimeerror: 1005
    Given property doesnt' exist ... TREND_PIC::PictFilter[0].Curve
    03.11.2015
    49
    Quote Originally Posted by daniel.lackner View Post
    Runtimeerror: 1005
    Are you sure the PictFilter[0] has properties available and the object exists?
    BR,
    Joris
  1. Display trend on Windows CE devices
    Last Post: 27th August 2007, 08:57
