Thread: Setup a filter at design time
    matholton Gast
    Default Setup a filter at design time
    hi there,
    I want to have 3 screen, showing alarms for a different PLC each (I.E. I have 2 PLC's linked up). The trouble I am finding is that I can only set the filter for each alarm list at runtime.
    Is it possible to setup a filter at design time, so each page only shows alarms from a specific group?
    thanks,
    mat
    Default Re: Setup a filter at design time
    at the picture switch function to the alarm picture, you actually define how the alarm page is filled (which filter is used).
    So by creating multiple picture switch functions, you can show e.g. all alarms, or alarms from a specific group or class.
    Of course it is also possible to modify the filter parameter of the existing picture switch function, through the properties window.
    matholton Gast
    Excellent Mark, thank you very much! :-)
  1. compare time variable with system time
    By flajoso in forum VBA
  2. flash-filter in the editor
    Last Post: 16th October 2007, 15:58
  3. WibuKey setup on 64 Bit Windows systems
    By juergen_fruehwirth in forum Engineering Studio & Service Engine
    Last Post: 19th September 2007, 15:05
