Thread: Working with 'OnlineVariables'
    robertf Gast
    Default Working with 'OnlineVariables'
    OnlineVariables are containers to recognize variable changes.
    This is the most efficient way to handle variable vlaue changes within VBA or external applications...
    [highlight=vb]Dim WithEvents zOLV As OnlineVariable
    Const strOLV As String = "MyOnlineVariableContainer"
    'initialize event on runtime startup
    Private Sub Project_Active()
    'get object if already exists
    Set zOLV = thisProject.OnlineVariables.Item(strOLV)
    If zOLV Is Nothing Then
    'if not exitst, create a new OnlineVariable container
    Set zOLV = thisProject.OnlineVariables.CreateOnlineVariables( strOLV)
    'add variables to the container
    zOLV.Add "Variable1"
    zOLV.Add "Variable2"
    zOLV.Add "Variable3"
    End If
    'activate 'VariableChange' event
    zOLV.Define
    'event is fired when a variable value changes
    Private Sub zOLV_VariableChange(ByVal obVar As IVariable)
    Dim vValue As Variant
    vValue = obVar.Value
    'ignore error values (i.e. on startup)
    If IsError(vValue) Then Exit Sub
    Debug.Print obVar.Name & " = " & vValue
    'release objects on closing the runtime
    'deactivate 'VariableChange' event
    If Not zOLV Is Nothing Then zOLV.Undefine
    Set zOLV = Nothing
    End Sub[highlight]
    robertf Gast
    Default Re: Working with 'OnlineVariables'
    This Sample uses an Array to store the actual Variable-Values for the best performance on reading variable values...
    The vba code has to be placed within the "thisProject" Classmodule.
    Dim arrValues() As Variant
    '| init onlinevariable to fill an array with variable values on change |
        ReDim arrValues(1, 2)
        Set zOLV = thisProject.OnlineVariables.CreateOnlineVariables("MyOLV")
            zOLV.Add "WIZ_VAR_10"
            arrValues(0, 0) = "WIZ_VAR_10"
            zOLV.Add "WIZ_VAR_11"
            arrValues(0, 1) = "WIZ_VAR_11"
            zOLV.Add "WIZ_VAR_12"
            arrValues(0, 2) = "WIZ_VAR_12"
            zOLV.Define
        Else
            MsgBox ("OnlineVariable ERROR, please restart!")
        End If
    '| release objects                                                     |
        Call thisProject.OnlineVariables.DeleteOnlineVariables("MyOLV")
    '| fill an array with the actually change variable values...           |
    Dim i As Integer
    Dim bAdded As Boolean
        'update value within the array
        arrValues(1, GetArrayIndex(obVar.Name)) = vValue
    '| get index of array entry by the name of the variable                |
    Function GetArrayIndex(strVarName As String) As Integer
    Dim i As Integer
        For i = 0 To UBound(arrValues, 2)
            If arrValues(0, i) = strVarName Then
                GetArrayIndex = i
                Exit Function
            End If
        Next i
    End Function
    '| get value of array entry by the name of the variable                |
    Function GetArrayValue(strVarName As String) As Variant
    Dim i As Integer
                GetArrayValue = arrValues(1, i)
                Exit Function
            End If
        Next i
    End Function
    '| Read Value by VariableName from array...                            |
    Sub ReadValue()
        MsgBox "WIZ_VAR_10 = " & GetArrayValue("WIZ_VAR_10")
