Thread: Alarm Handling
    22.08.2007
    20
    Default Alarm Handling
    I do have a variable of type Integer. Every single bit of this variable stands for an alarm. I tried to use the reaction matrix for getting the bit values but I have the problem with the priority included in REMA. It means when there are two errors at the same time, only one is displayed. Is there any better/easier way how to proceed these information in zenon?
    Thanks for any reply.
    Default Re: Alarm Handling
    you could split the variable into 16 boolean variables, e.g. using straton, to achieve independant alarms.
  1. Slow handling of objects in very large pictures
    Last Post: 29th October 2007, 14:00
