Thread: Edit Variable limit (Delay)
    rloureiro Gast
    Default Edit Variable limit (Delay)
    Hi!!
    i would like to edit the limit delay of a variable during runtime. Is it possible?
    I want to have on another variable, the delay value (in seconds) of the limit of the first variable.
    Thanks in advance.
    robertf Gast
    Default Re: Edit Variable limit (Delay)
    Hello rloureiro!
    It is possible to change the DelayTime at Runtime, but this manipulation is only temporary!
    That means, that a reloading of the project or restarting the runtime will bring back the settings configured in the editor!
    It is not possible to save this changes at runtime!
    Here is a small sample...
    Sub ChangeDelay()
      Dim zVAR As Variable
      Dim zLIM As Limit
        Set zVAR = thisProject.Variables.Item("WIZ_VAR_10")
        Set zLIM = zVAR.Limits.Item(0)
        Debug.Print "DelayTime: " & zLIM.DynProperties("DelayTime")
        zLIM.DynProperties("DelayTime") = 10
    rloureiro Gast
    Hi robertf,
    The script that you gave works fine.
    Thank you
    rloureiro Gast
    Sorry robertf,
    One more question.
    I tried to change the limite value of variable in runtime.
    I can read the limit value of variable and show this value on runtime, but i can't change his value.
    It's possible to do this? (change the limite value in runtime)
    Thanks in advance.
    robertf Gast
    Hi rloureiro!
    There is an easy solution without VBA...
    You can use additional variables for dynamic limits. Then you can set the limit-variables at runtime.
    The best would be to use variables from the Internal-Driver and the "Remanence" should be enabled...
    rloureiro Gast
    Thanks thanks
    Is an exelent idea, and solution
    regards
