Thread: Screen timer
    Default Screen timer
    I tried to search if there is a property for a screen to close after a define time but I could not find. I want the command pop up screen to automatically close if after ex. 20s no selection (open or close) is made, how can I do this?
    Thanks.
    18.07.2011
    138
    Default Re: Screen timer
    hi archie.
    You are looking for a timer. You might check on the zenon logic timer functions. Please see the attached screenshot for a help chapter reference.
    BR
    Hi Archie,
    You may also want to have a look at the system driver variable "idle time". This represents a incrementing counter that starts counting when the runtime is not being operated. You can easily create a limit function when it exceeds 20 seconds, that closes the frame used by your command screen.
    29.01.2016
    24
    I recently accomplished this using "Time Control" that had an entry that executed a function every second.
    That function reduced an internal variable.
    Then a REMA on the internal variable triggered another function when 0 was reached. That function closed the screen. So now I can have a decrementing counter that shows when the screen is about to close accurate to 1 second +- about 1 second.
    __________________
    having to do it YOUR way!
  1. Timer
    By zimou in forum zenon Supervisor
    Last Post: 18th July 2014, 12:56
  2. Screen Timer
    By rob.machin@capula.co.uk in forum zenon Supervisor
    Last Post: 21st February 2013, 11:54
  3. Timer for control
    By yara in forum Drivers
    Last Post: 28th January 2011, 14:32
  4. Wrong behaviour for timer/VBA
    By matholton in forum VBA
    Last Post: 1st November 2009, 15:58
  5. VBA Timer
    By hansvanzijp in forum VBA
    Last Post: 15th September 2009, 03:04
