Thread: Warning limit is 64KB
    29.01.2016
    19
    Default Warning limit is 64KB
    Hello.
    I have project in zenon logic and after compilation my code, zenon Logic tell me: Warning limit is 64KB.
    Is it means, that if I will have bigger project, I cant use zenon logic?
    Thank you.
    08.12.2015
    39
    Default Re: Warning limit is 64KB
    64KB is the size limit for a program/UDFB/function/... Also called POU (Program Organization Units)
    An application can contain up to 32000 POUs.
    I think your problem is related to the fact that one of your program is too big. Normally, depending on the version of zenon you are using, the name of the program should be indicated in the error message after building the project (first word in the error).
    Then the solution is to diminish the program size, if possible, or to separate it in different parts.
    Have a nice day,
    Anthony
  1. Element Warning..
    By fatih.oz in forum zenon Energy Edition
    Last Post: 16th July 2014, 21:28
  2. Warning POP-UP Screen
    Last Post: 5th October 2013, 12:15
  3. Zenon runtime security warning
    By jurijcadez in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 4th June 2013, 01:29
  4. Replies: 2
    Last Post: 16th August 2012, 14:19
  5. Zenon 6.50 Sp0 build 1 warning
    Last Post: 11th August 2010, 08:19
