Thread: Systemtexte in Schwedisch - Languagefiles in swedish
    04.12.2012
    Südschwarzwald
    5
    Default Systemtexte in Schwedisch - Languagefiles in swedish
    Guten Morgen!
    Kennt jemand eine Möglichkeit, die Systemtexte in Zenon in schwedisch zu Exportieren?
    Hatte jemand schon mal das Problem?
    ____
    Does anyone know of a way to export the system texts in Zenon in Swedish ?
    Had anyone ever the problem?
    MfG,
    Matthias
    22.03.2010
    18
    Default Re: Systemtexte in Schwedisch - Languagefiles in swedish
    Hi Mattias!
    Are you getting Swedish system texts or do you want to create Swedish system texts?
    Have you tried the "System Text Wizard"?
    It will create keywords in the language file for further translation.
    Check the documentation in the "Wizards" chapter.
    zenon isn't available in Swedish so you have to translate it with Google or some other tool.
    ______________________
    Fredrik
    13.08.2013
    57
    Additonaly if you are familiar with C# you could expand the System Text Wizards to suit your needs since it is available in the WorkspaceAddin. If you have a look at it you'll see that it uses a xml file C:\ProgramData\COPA-DATA\zenon$'version'\Templates\SystemTextWizard\Sy stemText.XML. In this Xml there are all Systemtextes for with various translations.
    So you could:
    Add Swedish Translation to this file
    Add GUI Elements for swedish
    Extend the wizard to also use swedish.
    Use the wizard for your projects
    Best regards
