Thread: Modbus Energy Driver // MiddleEndian
    philippevdt Gast
    Default Modbus Energy Driver // MiddleEndian
    I want to set up a Modbus TCP connection using the MODBUS ENERGY driver. The device I want to connect to, has its data available in Middle Endian format.
    Big Endan= B1 B2 B3 B4
    Middle Endian: B3 B4 B1 B2
    In the Modbus Energy driver, I can only choose between Big and Little Endian.
    Is there an easy way to read in data in Middle Endian as well?
    Philippe
    816
    Default Re: Modbus Energy Driver // MiddleEndian
    Middle Endian? No, not directly in the driver, too seldom.
    You may try a workaround:
    - read this register as two UINT values (or UDINT), set the "integer" variable(s) 'extern visible'. Do to forget to create 'Logic to SCADA connection' driver in Logic.
    - in Logic parse and reorder bytes and paste into an additional REAL (32 bits) stratonNG variable (or LREAL for 64 bits values).
    In Logic there are function blocks SerializeOut and SerializeIn to transfer any variable to/from a (local) array of bytes. So, you may call SerializeOut to transfer "integer" to some bytes in array, then reorder bytes, and using SerializeIn paste all bytes into float variable.
    philippevdt Gast
    Thanks for the fast reply ...
    (I feared having to re-order the bytes myself ...) :-)
    816
    let me know if it works for you
    24.09.2016
    I was looking for this info for a long time. Thanks.
  1. Per Shift Energy
    By tanveerali in forum zenon Energy Edition
    Last Post: 22nd May 2018, 12:40
  2. energy calculation in zenon 6.51
    Last Post: 2nd January 2012, 08:02
  3. Calculating energy
    By talal.mubarak in forum zenon Energy Edition
    Last Post: 15th December 2011, 11:53
  4. Replies: 1
    Last Post: 23rd October 2011, 23:09
