Thread: Zenon 7.0 ZenWorkspace.vba not working in fresh installed Windows 7 32 bit PC
    29.07.2016
    Default Zenon 7.0 ZenWorkspace.vba not working in fresh installed Windows 7 32 bit PC
    Dear,
    I am working with Zenon 7.0 which is working perfectly in any Windows 7 32 bit PC where already many software are installed. But in freshly installed Windows 7 32 bit PC, only framework related functions are not working. The software is getting installed properly. Do I need to install any other software to make it work? SQL2008R2 installed properly.
    Kindly help.
    Thanks.
    KamalikaS
    06.02.2012
    75
    Default Re: Zenon 7.0 ZenWorkspace.vba not working in fresh installed Windows 7 32 bit PC
    Hi Kamalika,
    May you check if the Microsoft .NET Framework 3.5 SP1 is installed on your system?
    If it is missing you can find it on the setup dvd in the ''Additional_Software'' folder to install it.
    All the best,
    Xandi
    PS: Check also the Visual C++ Redistributables please (if they are installed or not).
  1. PCE stopped working after license was installed
    By blazenzopavy in forum straton / zenon Logic
    Last Post: 24th November 2014, 14:46
  2. Text-to-Speech and Windows 7 64 Bit
    By daniela in forum zenon Network
    Last Post: 28th February 2013, 10:27
  3. Replies: 9
  4. WibuKey setup on 64 Bit Windows systems
    By juergen_fruehwirth in forum Editor and Runtime Setup
    Last Post: 19th September 2007, 15:05
  5. Replies: 0
    Last Post: 19th September 2007, 11:06
