Thread: Dynamic limit text in Dynamic Text element
    01.11.2012
    59
    Frage Dynamic limit text in Dynamic Text element
    Hi gents,
    I have REMA with Dynamic limit text messages.
    $(_;%variable;_) @text
    It works perfectly fine in AML and CAL for example
    (_ 123 _) Completed
    I would wonder if there is any way to display the output in Dynamic Text element.
    Kind regards,
    Sergiy
    846
    Default Re: Dynamic limit text in Dynamic Text element
    It is documented that dynamic limit text is not used in screen elements. This feature is supported only for AML/CEL as it is not possible to process updates of already generated texts for variable "varA" in case when value of another variable ("varB") - used in the dynamic limit text of "varA" - will change after the text was already generated.
    For screen elements you may produce nice texts in zenon Logic: set all variables used for dynamic limit text 'extern visible' and produce user-friendly texts on additional STRING stratonNG variables (or extern visible internal variables with calculation 'network'). Doing this make sure you have created in zenon Logic the fieldbus driver 'Logic to SCADA connection'.
    Note that the solution with 'extern visible', has a limitation: if an extern visible process variable changes value very fast, then the logic will see the latest value (one per cycle), not all values. Some short events can be skipped (overwritten in shared memory by newest change).
    So if your process variables are changing very fast you better use 'Allocations' module - to copy the process variables to additional stratonNG variables of the same data type. Then - "sooner or later" (later when system is overflowed with values) - Logic will be informed about each value - as the 'Allocations' in zenon and the stratonNG driver are working on events and making queues.
    01.11.2012
    59
    It is documented ....
    I've missed that point
    Sorryyyyyy
    But thanks for reply
    Kind regards,
    Sergiy
  1. How to Change color of dynamic text element
    By fred.tunell@dateli.se in forum VBA
    Last Post: 19th June 2014, 08:28
  2. How to size a Dynamic Text Box
    By pilzfrance in forum zenon Supervisor
    Last Post: 10th March 2014, 02:26
  3. Dynamic Limit Text and string variable value
    Last Post: 22nd March 2013, 09:19
  4. Why Dynamic Limit Text allows only 1 variable?
    By batabaha in forum zenon Supervisor
    Last Post: 1st May 2012, 23:51
