Thread: DNP_TG Issue
    yara Gast
    Default DNP_TG Issue
    Hello Support,
    In on of our projects we are using DNP_TG driver to communicate with GE RTU serialy using RS485 2 wire, all configuration we did is fine and the communiaction also was fine, after time we lost the communication and it is giving error in attached picture when we try to create all runtime files...
    Please advise ...
    Best regards.
    Default Re: DNP_TG Issue
    Hi Yara,
    Most likely, instead of using the driver property to open the driver configuration, someone used the driver property to create a driver simulation project.
    The error message indicates, that the existing driver simulation project, was not compiled in the zenon logic workbench.
    When you are not using the programmed driver simulation, it is safe to delete the driver simulation project, using the corresponding property in the driver configuration. The error message should then no longer be displayed.
  1. Zenon MultiUser issue
    By mmiencu in forum zenon Supervisor
    Last Post: 25th August 2015, 14:43
  2. Pingstate issue
    By whitetaru in forum zenon Network
    Last Post: 21st March 2014, 11:49
  3. Right Click issue
    By whitetaru in forum VBA
    Last Post: 26th April 2011, 06:46
  4. CE Login Issue
    Last Post: 8th February 2010, 02:29
