Thread: Used keywords from Zenon language file
    01.11.2012
    59
    Frage Used keywords from Zenon language file
    Hi all,
    I have some historical global project with language files (few languages)
    Next to it I have project for particular device which used translations from the global project.
    Are there any possibility to get the list of used keywords in this particular project in a screens and reaction matrixes etc. as a list of keywords to XLS/XML file?
    Kind regards,
    Sergiy
    10.12.2007
    192
    Blinzeln AW: Used keywords from Zenon language file
    This should be easily done with the language translation wizard. Make a Workspacebackup, then delete all language files and then use the wizard on the subproject.
    The wizard will create a language file with all keywords used in this project.
    01.11.2012
    59
    Daumen hoch Re: AW: Used keywords from Zenon language file
    Thank you for reply. I've learnt something new.
    Is there any option to know where each keyword comes from like cross-reference for screens? I have one which I don't know where it coming out.
    Kind regards,
    Sergiy
    13.08.2013
    57
    Default Re: Used keywords from Zenon language file
    There would be 2 options for this
    If you export the language table in the zip(via the wizard) there will be a xml called translation xml. There you'll find entries like this
    @Filter
    So you can find where the entry comes from.
    Otherwise if your familiar with coding the source code of the translation wizard, is in the workspaceaddin.
    You'll find a class called ZScreen which holds a List of ZElements, which itself holds the keywords it is filled in the method prepareCategoryScreens() and written in createXMLTranslationInformation(), with a conditional Breakpoint you could also find to which screen it belongs to
    Best regards
    Sigi
    01.11.2012
    59
    Hi Sigi,
    Thank you for prompt reply.
    Thats what I needed.
    Kind regards,
    Sergiy
  1. Replies: 5
  2. Replies: 1
  3. zenOn 6.50 paralel installation with 6.21/6.22 - language problem
    By micko in forum Editor and Runtime Setup
    Last Post: 24th March 2010, 11:13
  4. Sprachumschaltung Keywords
    By stefan.schilcher@gmx.net in forum zenon Supervisor
    Last Post: 23rd August 2009, 23:26
  5. Language Table Keywords and VBA
    By jhines in forum VBA
    Last Post: 18th September 2008, 14:52
