Thread: Zenon 7.11 is incompatible with Multiltin ( 61850 ) Protection Devices
    17.02.2016
    Unglücklich Zenon 7.11 is incompatible with Multiltin ( 61850 ) Protection Devices
    We are currently using Zenon V7.11 as our HMI / SCADA.
    We cannot get it to successfully get data from GE Multilin G60 and F650 Protection Devices using 61850.
    The issue is that the Zenon needs to set an integrity period when initialising the 61850 MMS Reports. However this functionality is not supported in this version. This seems a major omission as setting integrity periods by the client must be a "must have"
    Does anyone know a workaround?
    18.07.2011
    138
    Default AW: Zenon 7.11 is incompatible with Multiltin ( 61850 ) Protection Devices
    Hi Phil and welcome to the copa data forum.
    With zenon 7.20 some new features for reporting were implemented. Since then also integrity periods, buffer time, retries to enable RCBs and some additional optional fields can be configured within the IEC850 driver.
    Did you already check the opportunity to update your zenon Version?
    HTH,
    johannes
  1. REG-DA (IEC 61850) in Zenon 7
    By bnekooie in forum zenon Energy Edition
    Last Post: 19th January 2016, 14:47
  2. IEC 61850 to send variables from SCADA to ZENON
    By jonastj in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 27th February 2015, 13:30
  3. Chinese language on CE devices
    Last Post: 13th April 2010, 23:50
  4. I/O Devices
    By nahala in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 31st August 2009, 02:30
  5. Zenon project protection from uploading
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 11th June 2008, 10:35
