Thread: Web server client, blue dots when connected via internet
    25.05.2016
    6
    Default Web server client, blue dots when connected via internet
    Hi all,
    I have setup web server pro light and the global_vars.js settings. The web server and zenon 7,50 runtime are on the same PC so both runtime server name and web server name are the same in the global_vars.js
    this setup works over the internal LAN
    When i try to access server over the internet: servernames//zenon/index.htm i can see this page but when i start the web client via servernames//zenon/init.htm the runtime starts but cant get a connection to the server just blue dots.
    on page 49-50 of the zenon web server document, to allow port forwarding for port 1102 and give the PC a fixed IP. I'm not sure how to check NAT?? It says change the server name in the global_vars.js to the computer name of the gateway station?? is this the router? router has no name will IP address Work?
    James
    03.11.2015
    52
    Default AW: Web server client, blue dots when connected via internet
    Hello James,
    you can check the port connectivity from client to server with telnet.
    You could try to use the IP address (which is reachable from the web/public) of the server in the global_vars.js instead of using the PC name.
    How does that work out?
  1. Zenon Web Client and Terminal Server 2012
    By luca.bardon in forum Webserver/Webclient
    Last Post: 14th April 2016, 15:46
  2. Web Client
    By gyu in forum Webserver/Webclient
    Last Post: 4th March 2014, 08:27
  3. zenon Web-Client 7 -> Web-Server 6.22 slow startup
  4. Web client VBA
    By jurijcadez in forum VBA
    Last Post: 15th May 2012, 14:43
  5. Internet Explorer 8.0 for Web-Client ?
    By lephis in forum Webserver/Webclient
    Last Post: 3rd June 2011, 06:34
