Thread: Can not find Verbindungnamen in Zenon editor Version 5.5 SP7
    07.05.2016
    Default Can not find Verbindungnamen in Zenon editor Version 5.5 SP7
    I have a problem with Zenon v 5.50 SP7 that I can not find the Verbindungnamen in the S7 NT - S7 300/400 driver See attached file please! Iamge 1
    At Image 1 you will see that the S7 driver could not be able to show " zenOn" application and you will see also "the station configuration editor "where I had added the CP5611 and zenon application
    See also Image 2 the hardware configuration which I have done .
    So Kindly help me in this Issue because I have a problem in my factory.
    05.05.2016
    2
    Default Re: Can not find Verbindungnamen in Zenon editor Version 5.5 SP7
    Quote Originally Posted by m.aghory View Post
    I'm working on the same problem.
    Additional information:
    - The ZenOn software is installed on a Simatic PC 677B of part no. 6AV7876-0AA20-1AB0
    - The PC has an embedded CP of part no. CP5611/V3.0.1
    - The PC is connected to a Simatic PLC S7-315-2 DP of part number 6ES7 315-2AF03-0AB0/V1.2
    - The connection between the PLC and the PC (Through the CP) is by a ProfiBus network.
    The runtime always shows "PLC OFFLINE"
    106
    please change the driver configuration 'VFD names:' to zenOn instead of VFD_1
    The name of the application is the reference to get the 'Verbindungsnamen'= 'Connection Name' of your S7_Connection.
    Markus
    05.05.2016
    2
    Thank you, Markus. That fixed our problem and the unit is connected to the PLC now.
  1. software ZenOn 5.50 sp7
    By paheh in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 1st October 2014, 08:31
  2. How to installed Zenon5.50 sp7
    By lalitsharma2709 in forum Engineering Studio & Service Engine
    Last Post: 6th October 2013, 23:26
  3. Advantage of ZenOn Energy version versus Standard version?
    Last Post: 23rd June 2011, 23:54
  4. Replies: 4
    Last Post: 26th June 2009, 13:29
  5. Replies: 0
