Thread: Gantt chart
    29.01.2016
    19
    Default Gantt chart
    Hello.
    May I create Gantt chart just with IDENTIFICATION and TIMESTAMP(previous last)? My data: IDENTIFICATION, TIMESTAMP and VALUE(in value I have save time, how long was IDENTIFICATION active). It means, that I have save times form machine states in archiv.
    I need to create gantt diagram, where I see time machine status
    Thank you
    27.06.2011
    96
    Default AW: Gantt chart
    Hello DavidMarek,
    I believe you need to set up your variable differently. Saving the active duration as value is not how the Gantt in ETM works.
    What you need to configure is a variable that contains the satus of the machine as a value. In order to identify the different statuses you can use a recation matrix. Then save this variable in an archive with "record on value change" setting. This can then be used in ETM do display a Gantt chart. It will use the correct timestamps from the archive and display the limit text from the reaction matrix.
    kind regards,
    Alex
  1. WPF Chart Control einbinden
    By sudoaptget in forum VSTA
    Last Post: 3rd August 2015, 09:47
  2. Report Viewer Chart
    Last Post: 21st April 2015, 03:05
  3. WPF Pie Chart real time update
    By victorlin in forum VSTA
    Last Post: 15th April 2015, 05:10
