Showing results 1 to 7 of 7
Thread: Multiple variables
    29.01.2016
    19
    Default Multiple variables
    Hello.
    I would like to use array of integer. So I created multiple variable from 1 to 10 and dimension 1 [0..0]. Straton created me int[1]....int[10]. I created it in global variables. But the problem is, when I want use these variables in some function. Even if I use drag and drop into this function. When I compile code, Straton tell me unknown variables.
    This probem is just with multiple variable(array).
    Thank you
    105
    Default Re: Multiple variables
    If you named it really 'int[n]' then it is because 'int' is a keyword. Name it 'myInt[n]' instead.
    Markus
    29.01.2016
    19
    Hello. No name is array_readData_robot[1], ...[10]
    105
    Quote Originally Posted by DavidMarek View Post
    Thank you
    Arrays in zenon Logic are created from 0. so if you need an array of ten you will get variables array_readData_robot[0], ...[9]
    Markus
    29.01.2016
    19
    Even if I create from 0 to 9, still the same error: Unknown identifier.
    Dimension is set to 1.
    Thank you
    You need to create only one variable (MyArray) with dimension 10.
    Then in you program you can access to the element of an array like that:
    MyArray[0] := 20;
    MyArray[9] := 123;
    Jerome
    29.01.2016
    19
    Thank you
  1. Multiple selected math variables formula editing issue
    Last Post: 31st October 2014, 21:43
  2. Multiple copy of variables.
    By mjackson in forum zenon Supervisor
    Last Post: 17th September 2014, 14:45
  3. Multiple Variables assignment in Straton
    By shikra in forum straton / zenon Logic
    Last Post: 3rd March 2013, 23:36
  4. Multiple Monitors
    Last Post: 16th October 2009, 07:13
