Showing results 1 to 10 of 10
Thread: How do I use Variables?
    23.02.2016
    28
    Default How do I use Variables?
    Hi.
    Help is not listed.
    i want using variable.
    For example, I would like to put a value to a variable you created in advance.
    18.07.2011
    138
    Default AW: How do I use Variables?
    Hi.
    From your request it is not really clear what you would like to achieve.
    Could you please describe in detail what you are planning to do?
    23.02.2016
    28
    Default Re: How do I use Variables?
    I want to control the internal variables.
    08.08.2013
    44
    Hi backjahyun,
    in the following zenon help chapter, you get some further Information about the API-function.
    But basically it can be done as the following (of course, just in the runtime):
    this.Variables().Item("myVariableNameOrId").set_Value(0, 11);
    BR
    Christian
    23.02.2016
    28
    Thank you very much. Help not only VBA(Variable) examples.
    23.02.2016
    28
    my source code apply.
    this.Variables().Item("testint").set_Value(0, 100);
    messagebox show
    ->Back is not possible as there is no screen path yet.
    Why do?
    Default AW: Re: How do I use Variables?
    Hi backjahyun,
    Quote Originally Posted by backjahyun View Post
    messagebox show
    Why do?
    This message box is shown if you want to call a function of the type "Screen: Return to last" and there is no "last" yet.
    It is a function to navigate to the last screen on a specific frame (like an "undo" for screen switch functions)
    BR, Andreas
    23.02.2016
    28
    thank you.
    one more question.
    my source code.
    Microsoft.Vbe.Interop.Forms.ComboBox combo;
    public void Macro_Init_CombBox()
    try
    zenOn.IElement zElementActivX = this.Project.DynPictures().Item("Picture_Login").Elements().Item("ActiveX_16");
    as Microsoft.Vbe.Interop.Forms.ComboBox;
    combo = zElementActivX.AktiveX() as Microsoft.Vbe.Interop.Forms.ComboBox;
    //Clear the ComboBox
    combo.Clear();
    //Create Items for the ComboBox
    object[] captions = { "Mayer", "Schmidt", "Huber" };//아래에서 부터 0번재
    object defaultParameter = null;
    //Fill the ComboBox with Items
    int y = 1970;
    int m = 12;
    int d = 31;
    string a= DateTime.Now.ToString("yyyy");
    int lastYear = Convert.ToInt32(a);
    object k = 1970;
    for (y = 1970; y <= lastYear; y++)
    k = y;
    combo.AddItem(ref k, ref defaultParameter);
    catch (Exception ex)
    System.Diagnostics.Debug.Print("ERROR Macro_Init(): "
    + ex.Message + " " + ex.Source);
    how to my combobox current select item check?
    23.02.2016
    28
    I cannot find the selected item.
    08.08.2013
    44
    in general, you can find lots of information in the Microsoft Developer Network (MSDN).
    In the following link, it is mentioned how you can handle the selected item of a Combobox:
    https://msdn.microsoft.com/en-us/lib...code-snippet-2
    BR
    Christian
  1. PLC Variables and Internal Variables
    By madphilly in forum Drivers
