Showing results 1 to 8 of 8
Thread: compare time variable with system time
    flajoso Gast
    Default compare time variable with system time
    [i've started this Post in General Support]
    Hi all,
    my VBA skills are not very nice.. so i would like for some help, if possible.
    I'm trying to compare the actual system time with an interval time between two variables. I tryed it with 3 variables (2 for the interval and 1 to check if it is in the interval or not) and works fine. Now i'm trying to check with system time with "Format(now)" like an another user suggested me. The problem is that i cannot compare because of the variable types..
    Public Sub LeftClickDown_teste(obElem As Element)
    Dim mytime1 As Variable
    Dim mytime2 As Variable
    Dim mytime3 As Variable
    Dim state As Variable
    Dim teste As Time
    Set mytime1 = thisProject.Variables.Item("time1")
    Set mytime2 = thisProject.Variables.Item("time2")
    Set mytime3 = thisProject.Variables.Item("time3")
    Set state = thisProject.Variables.Item("timestate")
    'actual time
    teste = (Format(Now, "hh:mm"))
    ' this was a test with 3 internal variables
    'If mytime3.Value < mytime2.Value And mytime3.Value > mytime1.Value Then
    If teste < mytime2.Value And teste > mytime1.Value Then
    state.Value = "1"
    MsgBox ("TRUE") ' for debugging
    Else
    'MsgBox ("FALSE")
    state.Value = "0"
    End If
    'Debug.Print state.StatusString
    'state.Value = "1"
    End Sub
    robertf Gast
    Default Re: compare time variable with system time
    Hello flajoso!
    Please also post some samples of the values within the variables.
    Are these string variables or numerical variables?
    It is not that easy to compare times stored as strings, they have to be converted to values, either the ">", "<" ... can not work!
    If you post some more details, i can make a small sample...
    flajoso Gast
    Hi robertf,
    thank you for your reply.
    I think i know what the problem is. Vairables time1,time2 and time3 are Internal TIME variables in Zenon, and i can't "see" them as TIME variables in VBA, i "see" them as integers.
    What i want to do is the following:
    I have two times to be defined by the user: time1 (start time) and time2 (endtime). Every time the system time is between this interval, a bit should be ON.
    startime = 13:30
    endtime = 15:00
    if system_time > startime and system_time< endtime then
    'Dim mytime3 As Variable
    Dim now_time_str As string
    Dim mytime1_str as String
    Dim mytime2_str as String
    'actual time
    now_time_str = (Format(Now, "hh:mm"))
    ' i tryed to convert all the values to strings..
    mytime1_str = CStr(mytime1.Value)
    mytime2_str = CStr(mytime2.Value)
    'and then compare it like TimeValues.. the problem is that mytime.value is not in TIME format, it looks like an integer
    If TimeValue(now_time_str) < TimeValue(mytime2_str) And TimeValue(now_time_str)  > TimeValue(mytime1_str) Then
    state.Value = "1"
    Else
    'MsgBox ("FALSE")
    state.Value = "0"
    End If
    End Sub
    Thanks in advance!
    robertf Gast
    Hello again!
    If the Time in Variable "Time1" is 12:00 what value is within the Variable?
    12:00 = 43200 seconds ?
    12:00 = 720 minutes ?
    12:00 = 1200 ???
    There are several possibilities to convert, but to make a sample I need more detailed information!
    I know what you want to do, but I need some sample values. Either I am not able to do the converting correctly!
    It would be easy to debug the code, but therefor i would need your constellation...
    (project, data, ...)
    flajoso Gast
    in fact 12:00 = 43200 seconds, thats the value within the variable. I guess that i will have to convert it!
    Check my 'constellation'!
    Thanks!
    Attached Files Attached Files
    robertf Gast
    Hello!
    You can try the following sample...
    In this sample the seconds are compared...
    Public Sub CompareTimes()
      Dim varTime1 As Variable
      Dim varTime2 As Variable
      Dim varTime3 As Variable
      Dim varState As Variable
      Dim actTime As Integer
      Set varTime1 = thisProject.Variables.Item("Time1")
      Set varTime2 = thisProject.Variables.Item("Time2")
      Set varTime3 = thisProject.Variables.Item("Time3")
      Set varState = thisProject.Variables.Item("TimeState")
      'check if variables are advised!
      If varTime1.IsOnline = False Or varTime2.IsOnline = False Or varTime3.IsOnline = False Then
         'get seconds of actual time!
        actTime = (Hour(Now) * 3600) + (Minute(Now) * 60)
        'compare actual time with values from variables
        If actTime < varTime2.Value And actTime > varTime1.Value Then
          varState.Value = 1
        Else
          varState.Value = 0
        End If
      Else
        'Variables are not online, value is not present
        'needed to avoid errors on reading, if variables are not advised!
      End If
    End Sub
  1. Real-time performancce of STRATON
    By prasadkh in forum straton / zenon Logic
    Last Post: 12th December 2013, 12:31
  2. system time
    By flajoso in forum zenon Supervisor
    Last Post: 19th August 2008, 15:07
  3. How to have cumulative alarms time in report
    By fabios in forum zenon Supervisor
    Last Post: 21st May 2008, 10:08
  4. Local Day Time in format DINT
    By markusw in forum straton / zenon Logic
    Last Post: 12th October 2007, 09:53
  5. Value, Time-Stamp and status with allocations
    Last Post: 14th September 2007, 07:57
